T5 V8 swap parts
Car: 87 iroc 89 pearl white' black 06gto
Engine: 350 Procharged AFR, T76 383 miniram
Transmission: 700r4, 700r4, LS2 t56
T5 V8 swap parts
Hi guys I'm looking for V8 t5 bellhousing, clutch fork and pivot, and the clutch pedal. My car is a 89 camaro. I'm located on Horsham pa 19044
Thank you
Jimmy
Thank you
Jimmy
Re: T5 V8 swap parts
tko 600. how much for your setup? only the bellhousing, clutch fork and pivot, and pedals?
Car: 1986 z28 Camaro set for scca
Engine: 383 Carberated stroker motor
Transmission: LT1 T56
Axle/Gears: 9in with 3.50 posi
I have clutch fork, two different bellhousings ( blowproof and aluminum), and the pivot point. in pa
