looking for an sbc 350 shortblock
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700r-4
Axle/Gears: 2.73 lsd
i need a 350 shortblock thats prefferably fresh built or very low mileage in illinois/wisconsin/indiana
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: looking for an sbc 350 shortblock
Surprised you haven't got some responses! Too bad you're not closer to New Mexico. I'd fix you up.
Want a title? Post!
Car: 1991 Z28
Axle/Gears: 9 Bolt 3:73
I'm in wi. I have a 350 tpi L98 out of a 91 GTA that was rebuilt and ran for 3,000 miles. than the guy took it apart to build it up more, lost interest, and I bought it. currently it is 30 over and might need to be honed(I can have my a machine shop look it over). I have the complete engine(no wiring harness or computer), plus 60 over forged pistons and alum. heads off of an 86 vette. make me an offer.
Car: 86 IROC
Engine: 6.2
Axle/Gears: 10 Bolt 4.10
I have a ZZ4 shortblock with less than 5000 miles on it. It needs one GM iron lifter bore repair sleeve installed. The iron lifter bore sleeve is $3 from GM and any reputable machine shop should be able to press it in. I was going to get it repaired this spring so that I could sell it ready to go.
It comes with a Milodon oil pan, Melling oil pump, and timing set.
Car: 1991 rs, 1992 z/28
Engine: 363 ci chevy sb
Transmission: 700-r4
Ive got a complete shortblock that needs to be assembled. 4.060 bore 3.5 stroke 6" rods forged 10cc dish pistons. I have everything of the shortblock, I just decided to buy a 6.0 ls instead.1500 for everything. I have a thread in the engine parts section with pics.
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
I got a 350 TPI out of my '90 in the garage, but it has ~100k miles on it (TPIS air foil and 22 lb accel injectors).
Car: 1989 Iroc
Engine: In the works!!!
Axle/Gears: 9-bolt, 3.73 gears
I have the orginal block that came out of my 89. The block is empty but I can round up everything for it. The only thing is the pistons wont work cause the block is now bored .30 over and it has 4 bolt main caps in it now. It also has the deck o-ringed. PM me if you are interested. I'm in northern illinois.
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
Chevy3shitty
Sep 1, 2015 02:10 AM
Eric-86sc
Aug 24, 2015 09:01 PM
