[MI] Looking for LT1 swap powersteering lines.
Old Mar 11, 2011 | 06:14 AM
Kamaros's Avatar
Car: 1990 Camaro RS
Engine: LT1 350 5.7L
Axle/Gears: posi rear end
I have a 1992 camaro I did a LT1 swap on it and the engine came with a broken powersteering line. Does anyone make them?
Old Mar 18, 2011 | 07:16 PM
Datsun570Z's Avatar
Re: Looking for LT1 swap powersteering lines.
Too bad i did not see this earlier, I just junked my pws assembly.
Old Mar 18, 2011 | 07:21 PM
Kamaros's Avatar
Car: 1990 Camaro RS
Aww darn. Would it just be safe to run rubber hose from the pulley to the powersteering box/ gear box whatever you techies want to call it.
Old Mar 18, 2011 | 07:23 PM
Datsun570Z's Avatar
is it the high or low pressure side you need? Or is it from the reservior to the pump?
Old Mar 18, 2011 | 07:25 PM
Kamaros's Avatar
Car: 1990 Camaro RS
It's the one with the plug on it im not sure. It goes from the pulley to the steering box. The one on the resevoir is good.
Old Mar 18, 2011 | 07:30 PM
Datsun570Z's Avatar
You need to find out if its the high pressure side or not, if not then regular hose is fine but if its the high side you'll want to get some enforced hose.
On mine I just deleted the whole powersteering / AC setup.
Old Mar 18, 2011 | 07:40 PM
Kamaros's Avatar
Car: 1990 Camaro RS
Yeah I wouldn't mind deleting won't have to go though all the trouble with it. My buddy said to just find a fitting for the steering box and cut off the pinched part of the metal and run hose but I'm afraid the rubber hose will pinch when I'm turning the wheel. So any suggestions? Just a little bit of rubber hose won't hurt. Well reinforced hose that is.
Old Mar 18, 2011 | 07:41 PM
Datsun570Z's Avatar
Not really sure since my car never came with power steering to begin with. I have a Datsun 280Z with the LT1
Old Mar 18, 2011 | 07:47 PM
Kamaros's Avatar
Car: 1990 Camaro RS
Nice, I like nissans. I own a 1987 300zx turbod it has the vg30et. It's pretty dang fast, well that is when it was running. Im trying to diagnose it while I'm finishing up my camaro. I just need to fix the powersteering line and fine tune my carb. I carbed my lt1 because it didn't come with the Ecu.
Old Mar 18, 2011 | 07:50 PM
Datsun570Z's Avatar
Cool, I want your rear end off of that 300!
I have a spare 94 ecu laying around...
How hard was it to convert to carb?
Old Mar 18, 2011 | 08:22 PM
Kamaros's Avatar
Car: 1990 Camaro RS
Well it wasn't really that hard. I bought everything from summitracing.com you'll need the carb intake which is from gm. And you'll need a vacuum advanced distributor. Instead of the optispark distributor in the front. I'd recommend buying a block off plate after taking te optispark off. Well since you already have it Fuel injected I'd keep it that way better on gas. But it's your choice.
Old Mar 18, 2011 | 08:31 PM
Datsun570Z's Avatar
Oh I will be, I just spent $100 on a new eprom chip for my 93 ecu that i'm running.
Old Mar 19, 2011 | 12:39 PM
IROC-Z28_CAMARO's Avatar
Car: 1988 IROC-Z, 95 Z-28
Engine: 357, 350 LT1
Transmission: Built 700-R4, 6-Speed
Axle/Gears: 2.73 Peg Leg, 3.42 Posi
If it is the high pressure side I can make you up a hose rated for 4700 psi. You will need to buy one fitting for your steering box and one for your pump. If you want I can pit a kit together for you with fittings and hose. Just figure out how you want to route the hose from the box to pump and give me the length and I can make it up for you.
Lmk
Josh
Old Mar 19, 2011 | 04:01 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
I used a power steering line from a 95 (I think) Caprice with an LT1. All you have to do is bend the line that attaches to the pump. I bought it new from autozone, it was reasonably priced too.
Old Mar 19, 2011 | 06:55 PM
Kamaros's Avatar
Car: 1990 Camaro RS
Do you have an estimate of what that would cost?
Old Mar 19, 2011 | 08:30 PM
I could do a complete kit for you for 65 plus shipping.
Josh
Old Apr 9, 2011 | 04:52 PM
jagevileye21's Avatar
Car: 1991 Z28 Vert
Engine: LT1 350
Transmission: T56 6 Speed
Axle/Gears: 3.42 LSD
PM Sent
Old Apr 10, 2011 | 11:35 AM
Rich2279's Avatar
Car: '98 Mustang GT
Engine: '03 4.6L
Transmission: T45
Axle/Gears: DK
I did the same and still have it if needed. The line was on the car, but the engine was never started so no fluid went throught it. It is new, but I did bent it so it would fit in the 3rd gen.
Old Apr 10, 2011 | 06:07 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Purechoice can make them for you, and so can Street and Performance.
I am sure others can make them, too.
Old Apr 10, 2011 | 10:05 PM
Randy82WS7's Avatar
Car: 1991 S10 pickup 2700lbs
Engine: 4.3L Z TBI
Axle/Gears: 3.08 7.625"
caprice,. roadmaster, one of the caddies, the firebirds and camaros, and the vettes, all had LT1
we replacing broken 70k miles alum head LT1 in a 95 bird right now in the shop, sticking in a 94 roadmaster iron head LT1
something happend in the bottom end, wont hardly move, and oil is a little brown muddy sorta weird,
parting it out!
anyone needs any top end LT1 alum parts lemme know
or p/s pump, or front brackets stuff, or intake or fuel parts, or ignition parts etc, sensors,
everything....
its the DIS non distributor type ignition one, coil packs and external ICM on front of engine.,
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
