torque arm and corssmember
Old May 23, 2011 | 09:59 AM
steve90rs's Avatar
im looking for a 700r4 camaro crossmember and either a stock torque arm or used aftermarket. someone switched my car from 5 speed to auto and rigged up a torque arm mount on the crossmember and it keeps coming loose
Old May 23, 2011 | 12:04 PM
wesilva's Avatar
Car: 1966 El Camino Custom
Transmission: 200R4
Axle/Gears: 3:73 12 bolt with Brute Strength
Re: torque arm and corssmember
So I'm guessing your automatic transmission is not from a 3rd gen F-car. Otherwise you would have the proper tailshaft housing to mount the torque arm.
I'm not sure but it might be an cheaper fix to find the proper tailshaft housing and mount the torque arm up as it was intended.
Old May 24, 2011 | 08:49 AM
steve90rs's Avatar
do you know where i can get one? and they already butchered the torque arm so i atleast ned that
Old May 24, 2011 | 11:55 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Try a junk yard first, then look at;http://www.transmissioncenter.org/70...ail%20Housings
Old May 26, 2011 | 10:00 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
I have a stock torque arm $20 plus shipping from Michigan send me a PM if intrested
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
