[BC] Passenger side PCV valve hose (TPI)
Car: 1991 Z28 Convertible
Transmission: 5-speed
Axle/Gears: 10 bolt, 3.08
I think it is called a PCV valve. Anyways, the hose from the valve cover to the throttle body. Mine split at the TB.
$20 incl shipping (should fit in a bubble envelope).
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Passenger side PCV valve hose (TPI)
gm 10055872 the in the picture this item has been cut. the hose is longer and the valve cover is installed backwards. gmpartsdirect.co this hose is $9.67 plus s/h
The one in the picture is not my car but mine looks the same. It looks the same in my GM shop manual too. I possibly may have the name wrong. My local GM dealer looked it up and it was out of stock permenantly.
Engine: Lb9
Transmission: M20
this is the breather hose the pcv on the drivers side is discontunued. gm 14088538
http://www.whiteracingproducts.com/i...ducts_id=65987
I confirmed the one in the picture is correct looking. Speed Density or just later cars (mine is 1991) had the shorter one.
Anyone have one or know where to get??
1992 Trans Am
May 10, 2023 07:19 PM
