[Worldwide]T5 v8 bellhousing,flywheel(168t),pressure plate...
Old Jan 13, 2012 | 06:55 AM
Reni-Camaro's Avatar
Car: Camaro 1988
Engine: 305 14.5s 1/4mile
Axle/Gears: 2.73 LSD
Worldwide
bellhousing,flywheel(168t),pressure plate,clutch relese bearing for T5 v8
My location Ukraine Kiev
http://www.meest.net
Old Jan 17, 2012 | 06:07 AM
Car: Camaro 1988
Re: [Worldwide]T5 v8 bellhousing,flywheel(168t),pressure plate...
That no one sells?
Or does not want to send to Ukraine?
Old Jan 22, 2012 | 05:53 AM
Car: Camaro 1988
Really need to buy!
In our country it is impossible to buy!
Sell ​​someone!
You can via PayPal
Help!
Old Jan 30, 2012 | 05:23 PM
BOSS HOGG LOU's Avatar
Car: 87 IROC Z28
Engine: 5.7 TPI
Axle/Gears: BW 9 Bolt
Not sure if this will work for what you need, it may or may not. I have bellhousing with dual patterns that may work? Here is the link below. I would charge you $150 + actual shipping.
http://augusta.craigslist.org/pts/2826064467.html
Old Feb 4, 2012 | 03:03 PM
Car: Camaro 1988
Thanks but I do not work
Old Apr 12, 2012 | 08:27 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
82 mechanical bellhousing:
https://www.thirdgen.org/forums/engi...ml#post5222251
Also, the 168 tooth flywheels don't fit with a V8 T5 bellhousing. You'd need a 153 tooth flywheel.
Old Apr 13, 2012 | 05:00 AM
Car: Camaro 1988
but I need T5 v8 all swap kit 153 tooth flywheel!
luvofjah
Aug 5, 2009 11:35 AM
