[MN] WTB: Gauges, Fittings, MC Resevoir, Clamps, and a lot more!
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Need a *few* little things yet, but they really add up so if you have a used one or new one that's just sitting around let me know!
Autometer Ultra-Lite Gauges
-fuel level 0-90ohms 2 1/16
-voltmeter 2 1/16
-Electric Fuel pressure 0-100psi 2 1/16
-Electric Speedo 3 3/8
-Also need a Trans temp gauge, electric 2 1/16 Phantom series
Fittings and Hose
-Let me know what you have and are willing to get rid of, I need -6 through -12. Black fittings are preffered but other's will do!
-As for the Hose I need ~20' of -8, ~20' of -10, and ~10' of -12. These can be stainless or black braided.
Master Cylinder Resevoir
-A stock 3rd gen one would be perfect, but anything that can be mounted, sealed, and hold a cup or two of fluid would work.
Valve Cover Bolt
-From a center bolt gen3/4 valve cover, I only need one.
Lifter Trays
-NEW LS2 lifter trays. I know this may be a long shot but it's worth a shot!
-2.5" Clamps
-2.5" bullet mufflers x2
-2.5" X pipe
-2.5" exhaust pipes
-Hangers
Transmission
-Any t-56 slave shims
*Driveshaft Safety Loop for 3rd or 4th gen F-Body
*PST or Equivelent driveshaft, Stock length
*Rear End, 3rd gen width only, 4.11 gears or similar.
If you have any of the above post or PM me! Cash in hand or Paypal ready
-voltmeter 2 1/16
Fittings and Hose
Valve Cover Bolt
Lifter Trays
-2.5" Clamps
-2.5" X pipe
-2.5" exhaust pipes
-Hangers
Transmission
Car: 89 IROC-Z
Re: WTB: Gauges, Fittings, MC Resevoir, Clamps, and a lot more!
that mc resevoir is for the clutch master, not the brakes! sorry for any confusion
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
I have a stock clutch master cylinder with cap and black rubber insert and probably a valve cover bolt if I can find it. PM or email me your email address for pics and other info if interested, Henry
Car: 89 IROC-Z
PM SENT!
Car: 89 IROC-Z
TTT!!
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Hi, found a newer master cylinder with cap and insert and some valve cover bolts if still interested
Henry
Henry
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
TA8487
Aug 16, 2015 12:21 PM
Mister_Johnny99
Aug 14, 2015 12:59 PM
