86 TPI Fuel lines
Car: 86 Iroc-Z
86 TPI Fuel lines
building an 86 iroc i picked up for cheeeeep...needs the majority of the fuel lines replaced, buuut im having trouble locating the lines from any and pretty much all sources....anyone kno of any sources to locate these?? or even a functional used set would do for now..Thanks!!
Car: 89 Iroc Convertible
Re: 86 TPI Fuel lines
I should have the 2 short metal and rubber lines that go between the main lines and the throttle body
Car: 86 Iroc-Z
figures, the ones under the hood are the only ones that are still usable, thanks anyway, and ill definatly pm you if i end up needing them..thanks a lot!, i reallyy need the one that runs from the tank to the fuel filter, and the 1 from the after the fuel filter towards the front of the car.
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
Sanjay
Aug 12, 2015 03:41 PM
