Suspension
Old Oct 8, 2012 | 10:11 PM
cam-o's Avatar
Car: 1991 RS
Engine: 305 V8
Suspension
Any aftermarket suspension parts. Looking to get better handling. Whatever you have ill consider.
Old Oct 9, 2012 | 11:23 PM
Testa Rossa's Avatar
Car: 1983 Z28 - 1999 Tacoma - 1968 M715
Engine: none - 3.4L - 383ci
Transmission: 5sp T5 - 5sp R150F - 4sp SM465
Axle/Gears: none - 4.10 Toy - 5.88 D60/D70HD
Re: Suspension
Got a set of lowering springs and aftermarket swaybars.
Parts are a little warn so I don't know the brand for sure or how many miles on them (never actually got to drive the car). But if you want he whole set I cut you a good deal on them.
Old Oct 10, 2012 | 06:07 PM
cam-o's Avatar
Car: 1991 RS
Engine: 305 V8
Re: Suspension
Those look nice!
Is it just front springs or both?
Old Oct 10, 2012 | 06:13 PM
TPI-Formula350-'s Avatar
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Re: Suspension
https://www.thirdgen.org/forums/engi...r-control.html
Old Oct 10, 2012 | 07:22 PM
Re: Suspension
Pretty sure it has springs for both. Obviously the front is much lower.
Rear currently has no gas tank installed (which doesn't add much weight) and therefore no gas in it (which does add quite a bit). Couldn't tell ya how much difference that would make.
Have aftermarket swaybar both front & rear.
Old Oct 15, 2012 | 11:58 PM
Re: Suspension
Did a little bit of research... appears it's the complete Rancho system they offered back in the 80's... one of the few companies that had someting to offer. They don't make sports car systems anymore... An original "vintage" sport suspension...
Yeha whatever.... LOL
Don't see the name Rancho on the springs or sway-bar (long since been rubbed off) but the sway-bar mounts had the name Rancho stamped on it.
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
