[PA/MD] Looking for a posi disc rear
Car: 1986 Z28 Camaro Gunmetal Gray with
Engine: GM Crate ZZZ HO 350, Edelbrock head
Transmission: Rebuilt 700r4 all TransGo and Beast
Axle/Gears: 10 bolt with 3.73 gears
Hey guys, I am pretty open on what exactly it is, but I would like to be around 2 hours or less from york pa, unless its around an hour from the dc area since i visit there a lot. I want a posi disc rear, with at least 3.23 gears. 3rd or 4th gen, as long as its an easy swap into my 86. i would prefer a late 4th gen rear with the zexel torsen setup, next in line would be one 91+ with the 28 spline axles (i think?). anyways, let me know what you have and how much you want. thank you.
Car: 1986 Camaro Z28
Engine: 305 stock, 355 on the way
Transmission: 700R-4
Axle/Gears: 2.73 stock, 12-bolt with 3.90s soon
Re: [PA/MD] Looking for a posi disc rear
I know it does not have the gears your were looking for but I thought I would let you know.-Kevin
I have a rear for sale, came out of my 86 Z28. ( I bought a strange rear, drag car)
Codes from build sheet:
GU2 2.73 Axle
G80 Positract
J65 Disc Brake
It still has the posi tag on the diff cover
It has relatively new rotors and bendix pads. Pulled out of a runnning and driving car. Fluid has been drained as well.
I also have the stock rear control arms, shocks, and springs.
I would like to get $425 for all of it, I am located in Maryland near the Howard County Fair Grounds off of Route 70.
GU2 2.73 Axle
G80 Positract
J65 Disc Brake
hectre13
Dec 11, 2023 08:14 AM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
