AC Compressor Bracket 86 TA 4 bbl
Car: 1986 Trans-Am
Engine: 305 4BBL
Transmission: THM 700 R4
Axle/Gears: 2.73 Stock
I am looking for the bracket that attaches to the back of the AC Compressor and to the exhaust manifold stud.
It looks somewhat like an upside down Y when installed.
I have the other brackets 4 brackets.
I will buy the complete set if necessary (mounting bolts would be nice but not necessary).
Located in central PA.
Thanks!
Thanks!
Car: 89 IROC
Engine: LSX 6.0 370, TU2 Cam, Fast intake
Transmission: T56 w/ lots of goodies
Axle/Gears: 8.8, Posi, 4.10, 31 Spline
Re: AC Compressor Bracket 86 TA 4 bbl
got a pic as i might have it somewhere here
Car: 1986 Trans-Am
Engine: 305 4BBL
Hopefully the attachment worked the way I think it does. If so, this is the bracket I am looking for.
Oh, and if the spacer that is visible on the bolt at the top of the picture is available, that would be helpful as well. Thanks.
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
What is your ZIP code ?? ( shipping quote )
I know I've got the bracket & I'll check to see if I've got the spacer later this afternoon.
Wanted to update with a pic:
$15 + shipping for the rusty bracket and spacer.
$20 + shipping for the better bracket and spacer.
IIRC some set-ups had a "hole" so that emissions lines could pass thru the bracket. If you need to have a "hole" in it ( like the rusty bracket ) in better shape I'll double check for the proper part. Post your Zip if your still looking.
Car: 1986 Trans-Am
Engine: 305 4BBL
Sorry it took so long to get back. Busy all weekend.
The rusty one is fine. Nothing a little high pressure air and sand can't fix. Zip is 17847
Standard post and Priority were the same $8.90 + $2 if you want to insure it. I usually require insurance on all packages, but it's your call; I can't see it getting harmed, but insurance would protect against it getting lost in transit.
Send me a PM for the remaining details when your ready.
