[IL] WTB T5 VSS
Old Nov 8, 2013 | 08:36 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
WTB T5 VSS
as the title says, i need a VSS for my t5. preferably with the gear for a 3.42 rear end, if not, i can buy one.
Old Nov 9, 2013 | 07:08 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Re: WTB T5 VSS
You can get a VSS at the parts store. The gears, on the other hand, are another animal. You will need to look in the VSS hole and make sure the drive gear IS NOT the red one because you need the purple one and that one is a royal PITA to find. You will need an 18 tooth driven gear for the end of the VSS shaft, which is white.
Old Nov 9, 2013 | 10:32 PM
Chevy8588's Avatar
Re: WTB T5 VSS
ive got the correct drive gear, VSS is COMPLETELY discontinued. NO ONE carries one. not even rock auto
Old Nov 10, 2013 | 07:39 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Re: WTB T5 VSS
I'm seeing a Duralast SU1024 at AutoZone. I'm not seeing one for an auto, strangely enough.
Old Nov 10, 2013 | 09:39 AM
HankL69's Avatar
Car: 85 IROC / 69 Firebird convertible
Engine: 5.0 / 350
Transmission: t-5 / WC t-5
Axle/Gears: 3.27 / 3.08
Re: WTB T5 VSS
Correct me if I'm wrong, but isn't the vss part of the speedometer head in cable driven units. All that is in the transmission is the housing that holds the driven gear and connects it to the cable.
PurpleHaze92
Jul 13, 2007 10:28 AM
