Shopping List for 350/4L60E build w/ LT1 intake swap and LS1 PCM
Car: 88 GTA/86 C20 Burb/91 325i
Engine: L98/454/M20
Transmission: 700R4/NV4500/Getrag
Axle/Gears: 3.27 9-bolt/3.73 14 Bolt/3.73 IRS
So, I've been conjuring up my crazy schemes again, and I think I've got a shopping list ready for my build. Figured I'd shoot you guys some business if anyone has some of this to sell used in good shape. The general scheme is to pull the complete L98/TH700 and computer/wiring harness out of my GTA, and start over with a complete transplant using a spare 350 roller block I have laying around, and a whole lot of random pieces, attempting to maximize the Gen I small block for street/strip daily driver performance. Here's what I'm looking for in particular:
-LT1 Intake, throttle body, fuel rails, and fittings
-LT1 oil pump drive stub (like 1/2 of a distributor that bolts in place below the intake)
-SBC Aluminum heads. Must be 64cc or smaller chambers, and 195cc or less intake runners. I would prefer something along the lines of RHS or AFR 180cc heads. Not interested in 113 vette heads though.
-Comp Cams 268XFI cam
-Comp Cams 26918 beehive spring set
-Dyno Dons header setup and y-pipe for single cat exhaust
-Solid 4L60E transmission
-2000-2400rpm 4L60E Torque Converter
-LS1/4L60E wiring harness and PCM
-LS series Coil Packs and Brackets. Can be for any LS type car or truck as long as there is 8 of them and they match.
-Speed Density or LT1 cold air kit, preferably SLP
I will be adding to or modifying this list as the build develops. If you have any of this stuff for sale, feel free to PM me or post here. I will update the list as I acquire items that I'm looking for.
Thanks guys! One man's junk is another man's treasure.
-cal30sniper
-cal30sniper
Car: 1989 Iroc convertible
Axle/Gears: 3.08 posi
Re: Shopping List for 350/4L60E build w/ LT1 intake swap and LS1 PCM
I have a brand new trans go shift kit and the corvette servo for the 4L60E. I will sell it to you for dirt cheap. I will never use it. Sold my 97 z long ago.
bigjay89gta
Oct 15, 2015 08:04 AM
skinny z
Oct 5, 2015 06:23 PM
