[NM] 88-89 Maf sensor/ 88-89 5 SPEED ECU
Old Jan 11, 2014 | 11:04 PM
KMdoza7's Avatar
Car: 1989 IROC-Z28 Camaro
Engine: none
Transmission: T-56 W/ Spec 1 Clutch
Axle/Gears: 9 Bolt BW 3.27 Gears
Title says it all. Im looking for a maf sensor and a 5 speed TPI ecu years 88-89 Thanks.
Old Jan 11, 2014 | 11:32 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: 88-89 Maf sensor/ 88-89 5 SPEED ECU
Do you just need a 1227165 or the memcal as well ?
Old Jan 11, 2014 | 11:33 PM
KMdoza7's Avatar
Engine: none
Mainly just need the memcal. I swapped in a T-56 and i want a manual prom
Old Jan 11, 2014 | 11:36 PM
Engine: Lb9
Transmission: M20
I can program one for you or reprogram your old memcal if needed. I have tpi maf memcals for $120 shipped or can reprogram your if you have one for $65 return shipped with tracking. But I would need more specifics pm me if interested
Old Jan 11, 2014 | 11:38 PM
KMdoza7's Avatar
Engine: none
will i need an adapter or anything like that? or is it just plug n play?
Old Jan 11, 2014 | 11:42 PM
Engine: Lb9
Transmission: M20
No adapter, Either I can reprogram yours if you have one or one I have? I just need to know is this a 355 ? Manual trans Of course . Do you need emissions disabled , egr air pump ?
Vats disabled ? Engine modifications , cam heads ?
Would you want the fans to come on earlier ?
Old Jan 11, 2014 | 11:46 PM
KMdoza7's Avatar
Engine: none
i do have an ECU, ill PM you
Nick McCardle
Sep 10, 2015 08:36 PM
Eric-86sc
Sep 7, 2015 02:10 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
