[PA] need ebrake,parking cable
Old Oct 20, 2014 | 09:00 AM
jstricker5133's Avatar
Car: 1991 GTA
Engine: 5.0 tpi will be 5.7 tpi
I have a 92 gta, I swaped rear drums to disc. I need the cabe from handbrake to adjuster, for rear disc cars, as mine is now to long?
Old Oct 20, 2014 | 09:43 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: need ebrake,parking cable
Are you using the correct E-Brake cables ??
Old Oct 20, 2014 | 10:50 PM
Car: 1991 GTA
sorry 91 gta. ill try to explain with least amount of confusion. I had 2 1991 gtas. one with disc one with rotors. I ripped the rear end out of the one with rotors brake cables and all, but didn't keep handbrake cable. when I took the rear end out with drums all the cable were tight, put the rear end in with rotors and cables that were on rear end with rotors now the brake cables are too long by a couple inches. so there must be two different hand brake cables, or the brake cable brakets are mounted in different places between drum and rotor cars? does this make sense or am I being confusing?
///DAN///
Sep 25, 2015 02:15 PM
camaronils
Sep 20, 2015 02:57 PM
dbrochard
Sep 19, 2015 08:13 PM
corey8084
Brakes
Sep 15, 2015 08:14 PM
lock1983
Brakes
Sep 9, 2015 09:08 PM
