[NJ] WTB 9-bolt rearend housing
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Like the title says, Im after a 9-bolt housing from a car with disk brakes to build another rear. All I really need is the housing (center section + tubes) and the bearing caps. Id also be interested in buying a whole rear if someone has something like a complete 2.77 core they want to part with.
For the housing I would ask that its in reasonably good condition (inside close to rust free with no spun bearings or bent/damaged tubes or center section).
If your in Jersey or near it, Id be fine with coming to pick it up.
Engine: 4++,350 & 305 CIs
Re: WTB 9-bolt rearend housing
Ill be last in line but i do have what ur looking for in centeral IL
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I have one, no rust inside and almost no rust outside. I think someone painted it early in its life. I bought it because it was supposed to have a good posi, but the R&P were all messed up when the guy got to my house. I pulled the carrier out and degreased the inside. I bought it with the intent to do as you are and put it under my car.
Trenton area if you want to come look at it, it's in my basement as of now and won't be able to get great pictures right now. I can take some with the phone with the flash if you're interested
Car: 88 Camaro SC
Engine: SFI'd 350
Scooter,
Phone and flashlight will work
Im about 20 minutes away so the trip isn't too much trouble.
Im about 20 minutes away so the trip isn't too much trouble. Joined: Sep 1999
Car: 92 Firebird
Engine: 4.8 LR4
This is best I can do without pulling it outside and the cover off
Pardon all the sway bars there, I have a lot of car stuff down there.
PM me if you're interested
