[NC] WTB aftermarket suspension components
Car: 91 Trans Am
Looking for anything: SFCs, control arms, K-members, torque arms etc
Adjustable stuff is preferred but shoot me a PM or post here with what you've got
Only rule is no Spohn stuff
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: WTB aftermarket suspension components
I've got an adjustable front sway,.... 34mm solid. $85 + shipping. 1 of the mounting brackets is a little bent but should be pretty easily to bent it back in shape. Brackets mount on each control armwhere the control arm bump stops mount.
Post your ZIP for a shipping quote if your interested.
Found a picture from before I blasted the bar,... It's all red again now; Pulled it from under an 83Z and never installed it.
Also; That pic was named "32mmsolid" so my memory was probably wrong and it's more than likely to be a 32mm solid adjustable bar.
Car: 90 formula, 89 formula 350 vert
Engine: 305, 355
Transmission: T5, t56
Axle/Gears: 3:45 9 bolt, 8.8 3:73
John,
do you happen to know the brand of this sway bar and kit or does it look like a homemade deal? I only ask this because I really like how the end links look like a quick disconnect type setup.
Pretty sure it was a Rancho - or Ranchero. They quit selling Camaro stuff a LONG time ago. I got the rear springs and front bar from the car. All the suspension stuff was coated red. The end links are the adjustment points for the bar.
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
I have non-adjustable lakewood panhard rod and lca's. Also have unused founders bolt on lca relocation brackets. Pm if interested
Saxondale
Exterior Parts Wanted
Sep 7, 2015 06:11 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
