[MI] Th350 trans swap items
Old Sep 14, 2015 | 03:09 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Axle/Gears: 3.42 Detroit locker
I'm swapping out my 700r4 for a th350 and am hunting the swap parts. I have a short tail 350 that's been heavily built. I need the following:
-relocation crossmember with the torque arm mounts built in
-Or new relocation crossmember with the separate trans torque arm adapter
-th350 speedo housing and driven gear
-82-83 driveshaft
Let me know what you have and I'll be interested in sure.
Email if easier. Oostixz@comcast.net
Old Sep 16, 2015 | 07:59 AM
crazynights's Avatar
Car: 1982 Z-28
Engine: 383
Transmission: Turbo 350
Axle/Gears: Det. Posi, Superior Axles, 3:73 G
Re: Th350 trans swap items
Will you be selling your 700R4? I am considering to taking out my T350 and swapping in a 700R4, but I am looking for the later model 700R4, 30 Spline.
Not sure if I have anything you may be interested in. I do have the crossmember, but it's an 82 so the holes I think are different or I'm missing some holes. Thanks.
Old Sep 16, 2015 | 09:28 AM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Once I get the swap completed over winter I would then be considering selling my 700r4. It's origionally from a 91 firebird. As far as the cross member goes, I am looking for one, but I am not sure if the holes are different. I know the holes are different for the trans mount, as the th350 mounts like 2 in forward. But the mounting holes for the cross member to the body should be in the same spots. Atleast I'd assume
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
