[OH] WTB V-Belt Setup Brackets and Accessories
Car: 1987 Trans Am
My brother is looking at purchasing his first thirdgen roller project car so I thought I would test the waters and see what is available. Would prefer Ohio area so we can pick up since shipping on the brackets and accessories would likely be horrible.
If anyone has a setup let me know what type of price. Looking at v-belt since it will likely be cheaper if someone "upgraded" to serpentine and has the stuff laying around. Need at least the water pump, alternator, and ps pulley as a minimum with all the needed brackets.
Thanks!
Thanks!
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: WTB V-Belt Setup Brackets and Accessories
I've got the some water pump and crank pulleys,..... 1 set that's been restored as well as a factory used set. Do you need the 82-84 ( V-Belt Alt ) or the 85-87 ( ribbed Alt belt ) ? I should have some - if not all - of the brackets too.
PS The only PS pulleys I've got are still connected to a PS pump, Not sure if I have a Alt pulley that's not still mounted to an Alternator.
