Looking for T5 speed sensor
Old Jun 2, 2016 | 09:22 PM
Buttpole's Avatar
Car: 1990 RS Camaro
Looking for a working speed sensor for a T5 tranny. GM Part number 10456087. Let me know if you can help me out.
Thanks!
Old Jun 5, 2016 | 05:07 AM
formula00ra's Avatar
Car: 1990 & 1991 Firebird Formula 350's
Engine: 350 ci
Transmission: T 5 & 700r4
Axle/Gears: 3:23 & 3:27
Re: Looking for T5 speed sensor
I do not have the factory speed sensor but I do have the conversion unit and the bullet that fits into the transmission. The bullet is from a Camaro T5 so it is compatible with a speedometer cable. The conversion unit fits into the bullet and relay's the speed electronically. All you do is connect the wires to your existing auto trans wires and it works perfectly. You do know that even with the (VSS) speed sensor you're not going to get a correct speedometer reading without the correct drive and driven gears, don't you?
Old Jun 5, 2016 | 09:04 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I have one
Old Jun 5, 2016 | 10:25 AM
Buttpole's Avatar
Car: 1990 RS Camaro
What do you mean without the correct drive and driven gears?
