WTB Parking brake equalizer and speedo hold down
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: WTB Parking brake equalizer and speedo hold down
Pretty sure there is,...... I'll try to get some details and re-post here tomorrow.
Take a look at the E-Brakes 'main' cable in this pic & notice that it's got a metal sheath,..... I believe this is a 82-88 drum brake cable.
Now look at this pic, Notice that the sheath is covered in black plastic. ( That's not the only difference, the cable length is different and so is the way the cable fits into the cable sheath.) This is the same cable that's original to my 88 GTA with 82-88 Iron Calipers.
The cable with the black sheath is slightly shorter than the Cable without a black sheath. This is all the information that I have about this; I've never attempted to swap one for the other and there is just 2 things that I'm SURE about...... 1) my 88 with Disk brakes has a cable with the black sheath, & 2) the black sheath style cable is slightly shorter than the non-sheath cable.
Car: 91 Camaro RS
Engine: 305 TPI conversion.
It's adjustable so it will fit both. I went from drum to disc without issue
