[FL] 87 tpi fuel lines and smog tube needed
Hi guys.
I'm putting my 87 5.0 iroc back to stock. I need the 2 fuel lines that attach to the fuel rails and connect to the rubber lines on the frame. I also need the smog tube that runs along the back of the motor behind the intake that connects both sides of the smog. I could also use any smog hoses and factory plastic smog clamps . Any factory spark plug looms too. thanks! Steve
Re: 87 tpi fuel lines and smog tube needed
Nobody has any smog stuff laying around? I need the rear tube so I can set the motor in. Lokks like it will be a PITA to do it after the motor is in. thanks !
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got the SMOG crossover tube,..... I'll re-check this thread tomorrow to see if you still need it. Post your ZIP for a shipping quote.
