TPI EGR vacuum line
Old Mar 14, 2017 | 12:34 AM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
TPI EGR vacuum line
I am looking for the hard plastic vacuum line that runs from the underside of the throttle body to the EGR solenoid for a TPI car. Please PM me if you have one that is in really good condition.
Old Mar 14, 2017 | 03:12 AM
Drew's Avatar
Re: TPI EGR vacuum line
Assuming your rubber fittings can be salvaged, Dorman sells 5/32" vacuum tubing. Granted it's a bit softer than original equipment, but it looks the part. Heat it up carefully with a hair dryer or heat gun and you can shape it just like the real thing.
http://www.dormanproducts.com/itemde...6&SEName=47418
Old Mar 14, 2017 | 10:58 AM
I saw some of that, but I wasn't sure how to correctly make the 90* bend without the line cracking.
Old Apr 7, 2017 | 03:44 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I have a brand new nos set up. Let me check and see if I can find it.
