V belt pulleys and brackets
Old May 10, 2017 | 10:24 PM
rufaast's Avatar
Car: 88 IROC Z
Engine: temporarily stock
Axle/Gears: Stovk
I need all the brackets and pulleys and bolts for the v belt set up for SBC. AC must be on drivers side, see pic I need allparts shown
Old May 11, 2017 | 12:46 AM
Drew's Avatar
Re: V belt pulleys and brackets
FWIW, You might want to be a bit more specific. Do you need brackets for a TPI engine? Because the alternator bracket is different for TPI than a carb. Are you looking for the mixed V-belt and multi-groove setup as pictured? Because that setup was only used 85-87. The pictured engine is an 87 because it uses the CS alternator, 86 and earlier use the SI.
Old May 11, 2017 | 10:08 AM
rufaast's Avatar
Car: 88 IROC Z
Axle/Gears: Stovk
thanks for the FYI. I'm not using on a stock intake nor TPI intake. Using a Victor E for my setup . So alternator bracket bolting up to water pump would be better but one that bolts to intake would be fine as well
Old May 11, 2017 | 10:17 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
I have everything you need from an '85
Where are you located?
Old May 11, 2017 | 01:00 PM
rufaast's Avatar
Car: 88 IROC Z
Axle/Gears: Stovk
I'm in Tallahassee Fl, do You have any pics,
I've watched dyno don race back in the day 👍🇺🇸
Old May 11, 2017 | 02:27 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
I've got a couple pairs of 85-87 specific pulleys:
Stock set, Good condition = $55
Restored set, Blasted/Painted flat black = $75
+ shipping
I've got brackets and hardware too,... can't guarantee every piece, but should have most of them. Pretty sure they would be in stock used condition.
Edit: Smog & P/Steering pulleys fit all 82-87 and will be on the pumps,... & Alternator pulley will be on the Alt.
