WTB: White driven gear
Old Jun 15, 2017 | 05:04 PM
billym81's Avatar
I'm needing an white driven gear for an 92 camaro 5 speed. I think the part number is #14090592
Old Jun 16, 2017 | 10:20 PM
billym81's Avatar
Re: WTB: White driven gear
Does anyone have one or know where I can get one? I am also looking for the speed sensor for RPO code D8M as well
Old Jun 16, 2017 | 10:31 PM
henryd3's Avatar
Car: 92 Camaro RS
Engine: LO3
Axle/Gears: stock
Maybe if you indicated the sensor or fitting for this gear(what it goes to)
you would have better luck with responses
Old Jun 16, 2017 | 10:34 PM
billym81's Avatar
It is the gear on the vehicle speed sensor with the rpo code D8M which i posted above your post
Old Jun 17, 2017 | 05:04 AM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
This is where I get my Speedo gears from... They seem to have our can get anything and have good prices...
http://www.laspeedometergear.com
Old Jun 17, 2017 | 08:22 AM
billym81's Avatar
thanks, I looked on their site but did not see what I was needing, i might have called it by the wrong name. it's the little gear that's goes onto the shaft on the back of the vehicle speed sensor on the trans. I will see if I can dig up a pic
Old Jun 18, 2017 | 05:41 PM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
there are two kinds of speed sensors. 23mm and 10mm (I think) the smaller one is no longer in production. last one I had sold on ebay for about 150. the larger one is very common and cheap. it will not work in place of the smaller one. as for the gear, they are also very hard to find.
Old Jun 18, 2017 | 05:44 PM
billym81's Avatar
smh, not trying to be an a-hole, but I already know that info. the larger one can be brought on rockauto. that's why I listed the rpo code of d8m which is the smaller harder to find one
Old Jun 18, 2017 | 05:50 PM
tonys91rs's Avatar
Car: 91 Camaro RS
No offense taken. Someone out there may have the parts your looking for and didn't know there is a size difference between the sensors.
