[NC] 10 bolt posi rear differential
Old May 25, 2019 | 08:05 AM
coren's Avatar
I am looking for a new or used 10 bolt posi differential for 1986 Camaro IROCZ with 4 wheel disc brakes. I need minimum of 3:73 and would prefer 4:11 or 4:10. I need the diff carrier complete. do not need axle housing and do not want to dis-assemble the gear set for installation.
Old May 25, 2019 | 10:03 AM
IROCZman15's Avatar
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
Re: 10 bolt posi rear differential
I have the Auburn style diff and 3.73 gearset that I just removed from my 87 irocz in march 2018. the gears are richmond 3.73 with about 60,000 miles on them and zero issues. the diff is worn out and has 172,000 miles on it, but still worked when i removed it. it does have 1 of the 5 torx headed style bolts that hold the diff case together snapped off at the head, but the other 4 are in there good and tight. ring gear is still attached as are bearings. what kind of price were you thinking anyways?
Old May 29, 2019 | 03:24 PM
zman1969's Avatar
Car: 90 Formula 350
Axle/Gears: Dana 44 3.54
I have a set of 4.10 GM gears for 88$ shipped if interested, I also a 28 spline auburn posi but you would need 88 up axles as your 86 has 26 spline axles in it
I don't understand comment about disc brakes and housing not needed and all if you dont want to tear it down??
kyrenegade
Aug 11, 2018 10:37 AM
82 T/A
Apr 10, 2015 02:12 AM
norcalz28
Jul 11, 2003 07:55 PM
KeithO
Mar 30, 2002 06:12 AM
