summit assembled crate
Old May 13, 2002 | 04:00 PM
futureowner's Avatar
I went to summit racing today and was looking at their fully assembled engines. They had a Recon 350 chevy crate engine. I was wondering if any one has used this engine before? If so how was it? What other parts does this engine require to run? Here is what it comes with...
These 350 HP dyno-tested Chevy 350s feature a 4-bolt block (honed with deck plates), cast crankshaft, Keith Black hypereutectic pistons, I-beam connecting rods with ARP bolts, Melling high volume oil pump, a Crane 222/234 degrees duration hydraulic camshaft, Clevite main and rod bearings, and Fel-Pro gaskets. You also get World Products Sportsman II heads, Pioneer 1.5 ratio rockers, Eldelbrock Performer RPM intake, Dynagear double roller timing chain, oil pan, valve covers, and a timing cover. Dyno sheet included.
What do you guys think?
Thanks alot
RedLeader289
May 28, 2019 01:47 PM
school boy
Oct 22, 2015 11:47 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
gord327
Oct 3, 2015 01:25 PM
Giocio
Oct 1, 2015 12:20 PM
