easy swap??
easy swap??
would it be easy to swap a carbed 350 with an th-350 thats already in a 3rd gen camaro (hit from behind) in to a stock 92 RS 305 5 speed?...
Will the bellhousing and starter work?? I want to keep the 5 speed...
Headers off the 89 would work in the 92 right?...
What needs to be add/removed to make the swap easier (electronic wise)...
Any one done this swap before?...Any suggestions?
Heres a pic of the carbed 350....
Transmission: 4L80E/4L80E
"Easy" is really defined by the person doing the work.
Of all the things out there, though, this one should be one of the less complicated. A couple of things to watch are rear main seal type on the 350 (may be two-piece, in which case your flywheel won't fit), be sure to put a pilot bearing/bushing in the crank. Other than that, just switch things out/over.
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
hey fivekid,
i am not tryin to say u r wrong or anything but i have a 72 monte carlo 350 in my maro and the flywheel from the 305 fits the two piece rear main seal. never had a problem with it so is it u are saying it wont work? mine does. plus i thought 86 up 305s had the one piece. so the 89 or 92 will both have the one piece if it is the original engine and he shouldnt have a problem. i dont she a prob with the flywheel at all. please correct me if i am wrong but mine works fine with the 305 flywheel
1992 Trans Am
Aug 8, 2015 08:16 PM
