can a suburban's 350 fit into a camaro?
Old Jun 1, 2002 | 01:03 PM
viperwsu's Avatar
Car: 91 Camaro RS
My boss recently told me that he has a suburban's 350 core (everything from oil pan to valve covers), and he's willing to sell it to me for $350. He says that it has a little less than 100k miles on it, and ran but was making some rod noise when it was pulled. I am planning on having it rebuilt anyway, so the rod noise isn't a concern for me.
However, what I am concerned about it getting the thing to fit into my camaro without too many problems. I want to attach all the accessories (A/C too) to make it the same as a 1990-92 L98 TPI, but I don't know for sure if that is possible. Does anyone out there happen to have any ideas? I don't know the year of the suburban yet, but I'll post it as soon as I find out.
Old Jun 2, 2002 | 11:49 AM
ricktaylor's Avatar
Car: 84z28
Engine: 305h.o. mild mod's
Transmission: 700r4 shiftkit
your suburban 350 will go in fine, your accesory brackets naturally will look alittle different but wont be in the way of anything, noproblem
Old Jun 2, 2002 | 04:37 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
It will fit but i were you i would change the cam before you put it in your car.
Old Jun 2, 2002 | 07:59 PM
KZad's Avatar
Car: 88 Formula, 04 CTS-V, 06 Commander
Engine: 305 TBI, LS6, 4.7 V-8
Transmission: 5 spd, B&M Short Throw
It should be fine ... I am thinking about doing the same swap, mine coming from an 86 Suburban. We had ours out and rebuilt a couple years (18,000 miles) ago. Also had it bored .030 over while it was being rebuilt. Let me know how you make out.
Kurt
Old Jun 3, 2002 | 08:37 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It will "fit", but there could be things that don't bolt on if it is '86-earlier.
'85-earlier, your flexplate won't fit (use '82-'85 3rd gen type). '86-earlier, your intake will need mount bolt hole modification to fit. '78-earlier, the dipstick will be on the driver's side, which is a challenge to clear the exhaust manifold (but no problem with headers).
Old Jun 3, 2002 | 03:34 PM
johndo1707's Avatar
change the cam too, you'll thank me later,lol
Frozer!!!
Jan 19, 2024 04:55 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
ezobens
Aug 19, 2015 10:29 PM
Vintageracer
Aug 11, 2015 08:13 PM
armybyrd
Aug 10, 2015 09:23 PM
