Push rod length querstion?
Old Jun 11, 2002 | 01:53 AM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
I'm swaping from a 305TPI to a 350"TPI". Using a ZZ4 short block w/LT4 Hot Cam. AFR 190s milled to 64cc.
My question is; should I get/use stock roller valve train pushrods(7.200") or should I opt for adjustable pushrods? since the heads are not stock?
Thanks in advance.
Mike
Old Jun 17, 2002 | 12:47 PM
ede's Avatar
ede
if all you change is the heads and both blockes are/were roller blocks then you can keep the standard length push rods. you might want to consider aftermarket parts and check gemoetry to make sure all is well and no interferance problems. as a rule when i reach .500 or so lift i go another .1 on the push rods
RedLeader289
May 28, 2019 01:47 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
