For all you big block guys-a little help and answers-already searched the archives
Old Jun 15, 2002 | 12:39 PM
88IROCZJG's Avatar
Car: 1988 IROC-Z
Engine: stock L03
Transmission: auto
Okay. I can get a running Pontiac 455 backed by a Turbo 400 tranny for about $400. The guy who owns it claims that it's out of a 70 Firebird but I did research and none of the 70's came with a 455 so I am unsure of the year. It could possibly be a 400 but depending on year still have good HP and torque numbers. The motor is in a rust bucket 67 firebird now. I searched the boards and guys talked about having all the brackets? Are there different brackets that I would need than what is already there? This motor is complete and runs with all accesories now. Also, guys talked about how it is a very tight fit. I am prepared to get rid of everything like a/c, windshield washer fluid, etc. Emissions aren't a problem where I live. Will I need a new hood for it to fit or is the motor short enough it will fit as long as I stay with a relatively short air filter? Basically any info will help. A friends dad said he will help me make some motor mounts and I have about 4 experienced guys to help me with the swap. I plan on getting the motor and puttin in all new gaskets and bearings with a full tune up and maybe a new carb or rebuild the original one. The swap would not come until this winter when I have plenty of time for my car to be down. I need to jump on this motor soon so I can start the rebuild and before someone else gets it. Is $400 bucks worth the 335HP 430Ft/Lbs and the headaches? Also, if I get it I will sell my 85,000 mile L03 and perfect running 700R4 to help fund the project.
Old Jun 15, 2002 | 02:45 PM
Guest
Guest
Posts: n/a
Re: For all you big block guys-a little help and answers-already searched the archives
Where'd you get those numbers from? You gotta remember 1970 HP does not equal 2002 HP. Just another factor to consider.
Old Jun 15, 2002 | 03:27 PM
87RS402's Avatar
Well, ponchos didn't come in SB BB flavors, the only had one block and that one block would still be a PITA to shove into a 3rd gen. If your serious about stuffing a BB in that car go with a chevrolet block. Easier and cheaper in the long run, adn you can buy BBC cores for $400 if you look.
Old Jun 15, 2002 | 05:29 PM
88IROCZJG's Avatar
Car: 1988 IROC-Z
Engine: stock L03
Transmission: auto
well, I got those numbers because that is what some of the 400's came with in 1970 and I believe some of the 455's in 1971. By not being the same HP do you mean that over time the motor gets tired? The reason I was going to go with this motor is because I would get the good tranny to go with it and I know it runs. I wouldn't be able to afford to just get a core and buy everything to go with it. The guy who has the car now is out of work and needs money bad. Any other opinions? I was realy hopin this would work but its not lookin too good right now.
Old Jun 15, 2002 | 06:16 PM
Guest
Guest
Posts: n/a
Thats what I suspected. Those old ratings were SAE gross hp, nowadays everything is SAE net hp. The old rating in the newer hp numbers would be around 250-270. Just giving you a heads-up not to use those numbers for reference. The TQ on Pontiacs in general is awesome though.
Old Jun 17, 2002 | 07:24 PM
82Trans Man's Avatar
88 Iroc it is possible a guy by the name of Neal Owens (if I remember right) races a 455 powered 3rd generation trans am. I've been told that the third gen firebirds were originally desinged to take a 301 pontiac. I am going to be doing this in the near future once I get the engine together. The guy I bought the block and Nodular cranck from knows a couple guys who have done the swap and the hardest part is suppose to be the right (if I remeber may be the left) header. Headers must be custom built. A ton of people have told me that its impossible but I have seen a 87 with a 403 oldsmobile (79 outta a trans am) that a friend did but he ran manifolds so if you really want to it is possible just a ton of work and $. James
Old Jun 18, 2002 | 02:41 PM
85350TX's Avatar
If you want some help on this go to WWW.Performanceyears.com they have a section that handles this and also I cannot remember who it is but I think either Kauffman racing or Jim butler has a thirdgen swap kit for putting pontiac motors into thirdgens. Good luck
Old Jun 26, 2002 | 06:09 PM
9.0L Firebird's Avatar
Jack davis (Ontario, CA) makes headers, this is a popular swap for NHRA Super stock, as the Pontiac motors make great Torque and have a "softer" NHRA HP rating. I have a tall deck BBC in my car. If that will fit, a pontiac will. MAKE SURE it is a 455 (do some research) they all look the same externally, but a well built 455 is a torque monster. Tune up a set of later model 6X heads and you have a nice combination.
Juneb1022
Firebirds Wanted
Oct 12, 2015 08:12 PM
Slush92RS
Sep 2, 2015 08:56 PM
gixxer92
Sep 1, 2015 04:32 PM
sreZ28
Aug 14, 2015 07:48 PM
