LT1 power steering lines
Old Jun 25, 2002 | 08:18 PM
STRYKER's Avatar
Did you guys use the stock power steering lines off of the LT1 or did you make your own. If you made your own, where do I get the fittings ??? Thanks so much.
Old Jun 25, 2002 | 08:49 PM
Kory-88Iroc 350 tpi's Avatar
Car: 88 Iroc
Engine: 94 lt1 modded
Transmission: t 56
I had mine made up at napa
Kory
Old Jun 25, 2002 | 09:07 PM
Formie350's Avatar
I re-bent the stock LT1 lines.
Old Jun 25, 2002 | 09:15 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
I had some made at local shop, 6 AN high pressure braided stainless and 3/8" goodyear high pressure return black rubber, they also had the adapter fittings.
Old Jun 25, 2002 | 09:31 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
I also rebent the stock 4th gen ones.
Old Jun 26, 2002 | 10:22 AM
mat89RS's Avatar
Made my own with the 4gen ones using 3/8 stainless steel tubing and flared it with compression fittings, if you do the same, the compression fittings must be in a location where's there isn't too much vibration.
Old Jun 26, 2002 | 09:42 PM
STRYKER's Avatar
Thanks guys, I appreciate the info !
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
sreZ28
Aug 14, 2015 07:48 PM
