Is this a good deal for $5k?? Deposit Tomorrow HELP!!
Old Jun 27, 2002 | 04:40 PM
gtabadboy's Avatar
I might be making a deposit tomorrow help.
383 Chevy Long Block
Block: 4 bolt, .030 oversize hone w/ torque plates, zero deck block, align hone, new brass freeze plugs
Eagle 4130 forged steel crank (dynamically balanced), Eagle 5140 forged steel 6" I beam rods, JE forged pistons10.5:1 or 11:1, JE Plasma moly ring set, Clevite peformance series bearings, Melling HV oil pump and HD drive, Comp Cams flat tappit cam & lifters, Cloyes true roller Timing set, Factory oil pan 6 quart, Pioneer performance balancer, pioneer SFI approved Flywheel, Dart Pro 1 aluminum heads, Manley SS 2.05/1.6 valves, three angle valve job, Comp Cams springs to match, Comp Cams retainers and lock, New screw in studs and guide plates, Comp Cams pushrods, Comp Cams roller tip rocker arms 1.6
PRICE $4999 completely assembled and balanced, includes lifetime labor warrantee.
Is this a good deal, the guy said it will produce over 500 HP and should get my car in the 11s
Old Jun 27, 2002 | 07:45 PM
RSpeed's Avatar
Car: 92 Z, 91 Formula, 04 CTS, 01 Tahoe
Engine: 355 forged 4 bolt, SuperRam, 58mm t
Transmission: T5, looking for t-56
I don't think that is too bad,especially with the strong bottom end it is going to have with the 4bolt block and forged parts.Also nice set of heads and top end parts to get you over 500hp n/a.
Old Jun 28, 2002 | 07:02 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That's not too bad... slide a XE284H in it, put a Performer RPM and a Holley 750 on it, and a set of good headers, you should be pretty close to 500 HP.
Old Jun 28, 2002 | 10:57 AM
johndo1707's Avatar
go for it!
Street Lethal
Apr 30, 2019 12:14 PM
GTAman
Mar 15, 2019 11:40 AM
Thornburg
Aug 25, 2015 01:46 AM
CamaroZ_85
Aug 11, 2001 01:48 PM
Screamer27
Jul 27, 2001 10:09 AM
