Can't fit air filter!
What kind of intake man is on it? How big is the filter you're trying to use? Is there a spacer under the carb?
If you're thinking about modifying the hood I suggest using a cowl scoop just big enough to clear the air cleaner. Otherwise you're going to have a hard time seeing the right side of the car. Trust me I know. It's a pretty big project. You'd better be good with fiberglass and sand paper.
if its an open element air filter try and get a smaller filter and just cut the carb stud down to size so it fits nicely. but if ur running a small filter now then save up like 300 bucks or how ever much it is for a 2 1/2 in cowl hood from harrwood.
1992 Trans Am
May 10, 2023 07:19 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
