Trottle Body on LT1
Old Jul 2, 2002 | 02:49 PM
mat89RS's Avatar
Trottle Body on LT1
Can I put a 87 Trottle body on my LT1 motor ? Is it the same thing ???
I can have a SLP trottle body 900 cfm for 45$US...
Old Jul 2, 2002 | 08:47 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The sensors ( IAC and TPS ) have differant shaped connectors so they will need changed. Throttle cable is differant so that's another change.
Other then that it will bolt right up.
Old Jul 3, 2002 | 02:01 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Check the IAC casting, I think they are the exact same shape on the two..the LT1 will bolt to the bottom of the old TB, so you don't have to worry about you IAC..rewire the TPS and you're laughin'!!
Old Jul 3, 2002 | 02:10 PM
mat89RS's Avatar
Cool, thx. hey guys, I also have another Trottle Body of a regular TPI, 48 mm ... can I grind up all the midle meat and put one big air trap ? as this been done before ?
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
88 TA GTA
LSX and LTX Parts
Sep 11, 2015 11:31 PM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
