383 Build Parts
Old Jul 20, 2002 | 08:44 PM
duke_mushroom's Avatar
383 Build Parts
Ok, I'm starting to price things for my 383. I've got a lot of it done, but I have no idea what cam to use! If it helps, I will be using it as a daily driver but will still see strip/track use. I want as much power as I can get without going overkill, for a street motor I mean.
Old Jul 20, 2002 | 10:02 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I would call several cam companies tech lines to see what they recommend for your particular combination before making a decision on what cam to get. The weight, gearing, heads, compression ratio, and intended usage are all factors to consider when choosing a cam. If you can afford it I would definately consider getting a hydraulic roller. The GM "hot" cam is a good choice for a street/strip car, the specs for my cam are very similar to it. But once again it depends on your combination of parts so choose something that matches your particular car.
Reddeath210
Oct 6, 2015 08:20 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
sreZ28
Aug 14, 2015 07:48 PM
1nastygta
Aug 8, 2015 07:38 PM
