L98 F-body v.s. L98 corvette
Old Jul 21, 2002 | 01:10 PM
nitrobreth's Avatar
what's the difference between the L98's from f-body and corvette? the corvette has alumminum heads right? what else? intake, block, cam? thanks.
Old Jul 21, 2002 | 01:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Yes, Vette has aluminum heads (~'86-1/2 on). Shortblock and cam the same. Compression is higher because the aluminum heads have 58cc chambers vs. the 64cc of the iron heads (to make up for the power loss due to the higher aluminum heat transfer).
Vette intake is different because the aluminum heads don't have exhaust cross-over passages (different EGR setup), and the center two intake bolts on each side are the same as the others (unlike '87-later cast iron L98).
Old Jul 22, 2002 | 08:05 PM
PETE's Avatar
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
Also there is a debate about the block i've had two an 88 an 89 vette both came with 4 bolt mains. They weren't repo blocks or warranties yet other swear that they only came withn 2 bolt mains........
Old Jul 23, 2002 | 10:43 PM
iroc22's Avatar
All Vette L98's should be 2 bolt mains.
FormulasOnly
Jul 23, 2018 08:47 AM
88SS6SPEED
Nov 11, 2015 07:05 AM
the_hamturdler
Sep 30, 2015 12:50 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
