where can i buy a cheap shortblock?
Old Jul 21, 2002 | 09:01 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
327 or larger...............
i figure since i got the Z28 torn apart so much, an engine swap is nothing major right now
where can i get a cheap but good shortblock?
i already have the tranny out/ ex. manifolds off...............all i really need to do is undo the motor mounts and pull the engine
so, instead of having to go through all the trouble again, figure i'll do it now and save some hassles
Old Jul 22, 2002 | 08:10 AM
ROCKNRODS's Avatar
What do u consider cheap?
Old Jul 22, 2002 | 08:23 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
what do you consider good?
good — fast — cheap.... pick any 2
Old Jul 22, 2002 | 04:32 PM
ummmm decent internals
doesnt have to be top-notch, all-out-racing
something i can bolt some high quality heads and a nice cam onto and run a 12 second run the one time a year i get time to take it to the track........................................
ummmmm.......................below $1000...................
can be rebuilt, just needs to be done correctly
Old Jul 23, 2002 | 02:01 PM
ROCKNRODS's Avatar
I got my short block direct from gm spo u need an employee to purchase has to be cash at the dock.
short block for car was around 800
for truck (4 bolt main) under 1000
mine was for a boat ( 4 bolt better crank has to be better balanced or will shake apart boat) mercruiser part #under1200
if u r willing to come to flint mi i will help u get one
Old Jul 23, 2002 | 03:09 PM
i'm a GM mechanic, and i get employee discounts
is that what you mean?
Old Jul 23, 2002 | 03:59 PM
ROCKNRODS's Avatar
You have to work for gm not a dealer
then with a part # you can go to spo ( i believe it stands for service parts operation)and pick up for cost at the dock
I work for a dealer and I am not eligeble but my father in law retired from buick
I work 1 mile from the spo plant too
nugentcj
Camaros Wanted
Dec 22, 2015 02:58 PM
Doobie52
Sep 11, 2015 06:19 PM
Nick McCardle
Sep 10, 2015 08:36 PM
L0tuS
Sep 4, 2015 11:16 PM
