These heads any good?
Old Jul 22, 2002 | 12:51 PM
Bobbyz's Avatar
Car: 87 IROC Z "ZZ4"
Engine: 350 "ZZ4"
Transmission: ck performance th400 3000 stall
Axle/Gears: 3:73 10 bolt
I just ran the head casting numbers on my 350 this is what i came up with
462624.....75-86...350/400......76cc chamber, 1.72/1.5, 1.94/1.5 or 2.02/1.6 valves
are these heads any good? also one site i went on said these heads are crack prone. are they worth a rebuild?
Old Jul 22, 2002 | 01:13 PM
ATOMonkey's Avatar
They're smog heads. You could put money into them, but unless you do your own grinding and cutting, you probably won't come out ahead. BTW, if they don't get hot they probably won't crack. The car that they are in has more to do with engine failure than the engine.
Old Jul 22, 2002 | 01:14 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
They are garbage. Please have them melted down, to protect the universe from 170 HP 350s and 400s
Old Jul 22, 2002 | 03:03 PM
Bobbyz's Avatar
Engine: 350 "ZZ4"
So im probably better off going with the set of vortec heads i might get off a friend, also the block number is 3970010 i ran those numbers and it came up with
350...69-80...2 or 4 bolt main
another site says it was used in some high performance applications
low power 180
high power 370
car,truck,vette
does this mean the motor has 370 hp?
Old Jul 22, 2002 | 03:40 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No... it had 170 or 180 HP.
010 blocks were used in everything from 350 Nova 2-barrels to trucks to Z28s and Corvettes. It's a block, nothing special one way or another. The HP rating depended on what heads were on it, what pistons were in it, what induction system it had on it, and what ratings standard was used at the time the rating was conjured up.
A 350 with 462 heads was probably one of the 2-barrel variety. So the pistons would have been the dish kind that always was used with the extremely low-perf smog heads.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
NinjaNife
Aug 23, 2015 11:49 AM
