Which Cam for 305 to 350 swap
Old Aug 19, 2002 | 12:50 PM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
Transmission: Tremec T-56
Axle/Gears: 10 bolt/3.42
I will be swapping in a 350 for the 305 in a couple of months, I will be getting a short block out of a '97 truck (I think) and I am getting the SR Torquer heads for it but I am not sure which cam to get. I was looking at the following:
LT1
LT4
LT4 Hot Cam
ZZ4
Which cam would you guys suggest I get for my 350 swap.
Old Aug 20, 2002 | 11:49 PM
PONTIMANIAC 90's Avatar
Car: 1990 Formula
Engine: treefitty
Transmission: stick
LT4 Hot Cam! Then again I might be biased since that's what I used it w/my AFR 190s.
Old Aug 21, 2002 | 10:31 AM
Js92RS's Avatar
Car: '92 Camaro RS
Engine: 355 TPI
LT4 Hot Cam it is! A couple of other guys recommended this cam as well.
Jake_92RS
Jan 28, 2020 10:37 PM
bellez77
Sep 5, 2015 08:39 PM
camaro71633
Sep 1, 2015 10:24 AM
armybyrd
Aug 10, 2015 09:23 PM
gwade12
Aug 8, 2015 08:17 AM
