help
Old Aug 24, 2002 | 04:19 AM
ChickenFried's Avatar
help
I just put a 355 with a carb in my 91 rs. I also swapped the t5 for a 700r4. The damn car won't start. the starter does nothing. I tried connecting the neutral swith that went to the transmission and I hold down the clutch to hit the switch behind the pedal but nothing happened. I checked for power in the purple and yellow neutral safety switch wires and the ones that went to the tranny have power but the ones behind the clutch do not. I have no clue what the problem is. Is there something that needs to be hooked up that I didn't use or what. Give me some ideas of what to try please.
Old Aug 24, 2002 | 07:17 AM
ede's Avatar
ede
have you checked for power to the starter? not a VATS problem? what do you mean "you tried connecting the nutral switch"? you should be able to jumper it to by pass it
Old Aug 24, 2002 | 10:24 AM
I did just use a jumper in between the wires. There was power to the starter from the battery cable (obviously) but the small wire on the solenoid had no power when I tried to start it.
Old Aug 24, 2002 | 01:42 PM
I figured it out. There was a ground wire hiding from me.
