aftermarket pulleys, year descrepancy
Old Sep 4, 2002 | 07:07 PM
CamaroFreak87's Avatar
Car: 1987 Camaro IROC Z-28
I have an '87 IROC with an '87 engine. Can i buy the March Performance pulleys, 3 piece, for an '88+ camaro? I know the difference is one is V-belt and one is Serpentine, but say, I wanted to change my car over to a Serpentine system, would that work? Thanks.
Ryan
Old Sep 4, 2002 | 07:30 PM
Guest
Guest
Posts: n/a
It'll work fine, if you change the rest. You'll need (I think, 3 piece pulley kit is probably crank, alt, water pump) PS pump pulley, AC pulley and smog pump pulley, if it has those items on the car. Not to mention the brackets they mount to, and tensioner. AFAIK there isnt a way to run a serpentine setup on the stock accessory locations, I dont think things line up right.
Theres a tech article floating around on a pulley swap. I think its on sethirdgen.org or something. I dont think you can just change the AC pulley real simple either,
Old Sep 4, 2002 | 07:45 PM
well, that's a bummer
Old Sep 4, 2002 | 09:53 PM
Guest
Guest
Posts: n/a
Yea, it sucks. I have one of both, the serpentine setup I do like the looks of better, and it probably robs a few less HP. Oh well.
evilstuie
Jan 9, 2020 08:29 PM
evilstuie
Apr 14, 2016 08:52 PM
LittleFranks
Sep 17, 2015 12:22 PM
Navy8125
Aug 22, 2015 07:13 PM
Street Lethal
Aug 12, 2015 11:33 AM
