Whats the difference between internally and externally balanced?
Old Sep 27, 2002 | 01:38 PM
Berlinetta's Avatar
What is the difference? For some reason its confusing the hell out of me. If i get my crank balanced does that mean its internally balanced? I need you guys help on this one.
Old Sep 27, 2002 | 02:22 PM
GTA-SPD's Avatar
Car: 94 Corvette
Engine: LT-1
Transmission: Freakin Automatic---For Now
Externally balanced engines are balanced as an assembly with counter weights on the flywheel and/or the balancer. They scrapped this plan because it was a pain and not as effective as balancing each component seperatly. That is the easy way to explain it. Basically, a 400's crank, flexplate,and balancer are unbalanced until all assembled with the counter weight. On a 350 (& 305) the crank, balancer and flexplate/flywheel are all balanced seperatley so, therefore the assembly is balanced. That is why you can bolt a manual flywheel where anautomatic flexplate was on a 350 and not have any problems, not so with the 400. Ther, I think I've gotten that issue about as clear as mud for you. LOL
BAMiller
Sep 14, 2015 06:38 PM
fasteddi
Sep 10, 2015 09:32 AM
IROCtometal
Sep 9, 2015 10:01 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
greenyone
Sep 2, 2015 03:39 PM
