Porting intake
Car: Camaro
Engine: lt1
Transmission: 4l60e
Axle/Gears: 3.27 9 bolt
Porting intake
What needs to be done to port an intake manifold? How much of a power difference is there between a ported stock intake and an aftermarket intake?
Car: Camaro
Engine: lt1
Transmission: 4l60e
I have 2 intakes, one of a 82 lg4 305 and one off of a 305 from an 81 chevy van. I dont know what intake you could get more flow out of.
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
Try doing search on this topic. THere should be lots for you to find out. Porting the intake will make a considerable difference to your performance. Rpm's will be able to climb a bit higher too. Aftermarket would be better, but not that much unless you match it all up porperly. Try a search and see what you find.
if everything is stock, you will not notice too much of a differnce. You would have to port match your intake to your heads for the best performance gains. Aftermarket intakes are MUCH better, you can get a good one for around $100-$150. I would just go that route than port match.
Transmission: 4L80E/4L80E
Is either of these manifolds aluminum? If not, it absolutely isn't worth it.
Gasket matching the intake can actually hurt driveability, especially with a healthy cam. What you really want is the manifold ports to be slightly smaller than the head ports. This helps keep the flow moving in the desired direction ("anti-reversion", it's often called). Same goes for the exhaust, but the other way - you want the head ports to be slightly smaller than the manifold/header opening.
toronto formula
Sep 10, 2015 07:31 AM
