Base 350 Crate Questions???
Old Dec 17, 2002 | 06:33 PM
Cloud VF102's Avatar
I switching to a Crate Base 350 from pace warehouse and am wondering what will i have to do to make switch this over successfully.... I have 305 TPI new and Tranny is new.....
Old Dec 17, 2002 | 07:00 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
What year is your current engine?
About the only issues at all are the rear main seal type (the base engine is '85-earlier two-piece type, which affects the flex plate type) and intake manifold center-two bolt angles (on each side - base engine is '86-earlier type, but you can elongate the bolt holes in the manifold to get it to match up).
Other than that, it's a simple long-block swap. You most likely won't even have to worry about injector size or PROM tuning, since the base 350 is a very mild engine.
theshackle
Sep 17, 2020 08:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
