Tell Me What You Think Need Some Help
Car: 1988 GTA
Transmission: TH350
Alright i need some help building my engine. I want it to be a 355 that going to be able to handle a TNT nitrous wet kit 150-200hp kit. I want the engine to push around 350-400hp without the nitrous. This is going in an 88 GTA. Heres my thoughts so far.
AFR 190cc or 195cc heads
Holley Stealth Ram Intake
Comp. Xtreme Energy Cam 276/281 224/230 .503/.510 112LS
Comp Cam Pro Magnum 1.6 roller rockers
SLP 1 3/4" Headers
3" Cut-Out
3" Flowmaster Exhaust
52mm Holley Throttle Body
Custom Cold Air Intake
B&M 2400 Holeshot Torque Converter
3.70 gears (9 bolt)
Spohn suspension ( torque arm, LCA, LCA relocation brackets, and panhard bar)
I'd like to here your comments on this setup.
I also would like to here some suggestions on building the bottom end of the engine.
Also if 400hp is possible with this setup
SLP 1 3/4" Headers
3" Cut-Out
3.70 gears (9 bolt)
