LT1 Swappers and the Swap Guide
Old Dec 24, 2002 | 11:55 PM
TexasLT1's Avatar
Car: '92 RS
Ok, I guess the easiest way to do this thing is going to be for everyone to post as much general information about their swap as possible, and then we can all e-mail more detailed information and photos and stuff if necessary.
Engine:
'95 Z28 with Auto, used T-5 and had computer reprogrammed
Wiring Harness:
Modified stock harnesses
VATS:
Yes
A/C:
Yes, used CarQuest adapter, kept compressor in 4th gen location, notched frame
Powersteering:
Mounted reservoir on custom pedestal next to coolant overflow tank. Used original hardlines under radiator to connect to steering box.
Fuel delivery:
Kept most of 4th gen plastic lines and 3rg gen hard lines. Used custom lines with -AN fittings and barb fittings to mate two together.
Stock TPI in-tank pump
Cooling System:
Stock 3rg gen radiator and fan. Goodyear wire-bound hoses connected 4th gen style.
Driveline related:
Original T-5 with Centerforce DF clutch. '95 Z28 posi unit with 3.42 gears
Old Dec 25, 2002 | 09:47 AM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Driveline: 1993 LT1, with stock 1990 700-R4
Wiring Harness: Modified stock
VATS: NO
AC: Notched frame, but havnt made line yet.
Fuel Delivery: Walbro 255lph intank, 3rd gen Lines with 4th gen ends welded on.
Cooling system: 4th gen Radiator and dual fans. Used 3rd gen fan shroud.
Drivetrain related: Vigilante torque converter, 87 Posi 3.73 9 bolt with 93 Z28 Brakes.
Old Dec 25, 2002 | 10:58 AM
mat89RS's Avatar
Driveline: 1993 LT1 - Aluminium Heads
Wiring Harness: What came with the engine, just merged with the old one.
VATS: Yes
AC: AC delete pulley
Fuel Delivery: 1992 TPI fuel sending unit
Coolint system, Corvette 1994 Rad
Tranny: 1993 4L60 Non electric, the only years like that. Kevlar clutchplates, different valve body, corvette servo.
Power Steering: Same as TexasLT1
Old Dec 25, 2002 | 02:05 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Engine: 93' LT1 -f body.
Intake / computer / wiring- stock 94 f body.
VATS: painless bypass module.
Fuel delivery: new stock tpi replacement pump on stock sending unit, custom stainless braided AN lines sending unit to fuel rail, reused LT1 rail connector.
Power steering: custom AN high pressure hose and high pressure rubber return.
A/C Delete: GM idler # 10115875
Trans: 94' T56, dual friction clutch from local shop, spohn stock type crossmember notched to clear alston racing tubular sfc's, Pro 5.0 shifter.
Gauges: all electronic autometer ultra lite, inlcuding 160 MPH speedometer.
Exhaust: 1 3/4" non AIR single cat slp headers, 3" cat, 3" pipe to single in/out hooker aerochamber with 3" 90* dump.
Air intake: GM 1LE bellows with 3.5" id K&N cone clamped to MAF.
Cooling: Stock 4th gen radiator and fans, moroso fan turn on kit auto 185* primary, switched secondary.
Old Dec 25, 2002 | 02:27 PM
Drastius's Avatar
Car: 1985 Camaro Z28
Engine: Caprice LT1
Engine: 1995 Caprice 9C1 Police, Iron Heads
Wiring Harness:
VATS:
No, programmed out by PCMforless.
A/C:
No, 1LE A/C delete Pulley.
Powersteering:
Mounted reservoir by Strute Towe. Used hardlines from Caprice going under radiator to connect to steering box.
Fuel delivery:
Used tank and hanger from TPI car, rubber lines connecting to Caprice nylon lines with quick connect fittings at engine.
GM high performance pump (can't remember LPH at 44 PSI).
Cooling System:
Silicon hoses stock from Caprice, new replacement 4th Rad. Dual electric fan setup from some type of 3rd gen. 160* programming and T-Stat.
Driveline related:
95 4L60E, stock 3.08 Rear End (ugh).
Old Dec 29, 2002 | 12:08 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Engine: 1995 Caprice 9C1, Iron Heads
Wiring Harness:
Modified Stock Harness
VATS:
No, Programmed out by Me
A/C:
No, 1LE Delete Pulley
Powersteering:
Haven't done it yet
Fuel Delivery:
External In-Line Holley 255lph Pump, running -8an braided lines to fuel rail and -6an braided lines back to the tank.
Cooling System:
Stock 3rd gen radiator, Dual Fan Setup, 160 stat
Driveline:
3.42 4th gen rear, no tranny at this time, stock driveshaft.
Other mods:
LT4 Heads and LT4 Intake, upgraded valve springs, running in Speed Density Mode,
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
