Confirmation on LT1 Swap
Old Jan 24, 2003 | 10:51 AM
ZipTriX's Avatar
I finally found an LT1/T-56 setup for $2500. I just need to know if it has all parts needed for the conversion into a 92 RS.
Engine Parts:
Motor
All belt driven accessories
ECM
Wiring harness
MAF Sensor
Exhaust manifolds
Starter
T56 Parts:
Pedals
Cluth cylinder
Shifter
Clutch
Bellhousing
Thanks.
Old Jan 24, 2003 | 02:51 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
You are going to need some other things, but thats got just about all you need from the donor car.
Old Jan 24, 2003 | 03:28 PM
ZipTriX's Avatar
What other parts would I need? Just want to get all the parts in advance, so I don't have any "loose ends" when working on it.
Old Jan 24, 2003 | 03:33 PM
badandy247's Avatar
Car: 91 Camaro RS
Engine: 3.1L V-6
Transmission: Fresh 700R4
get the gas tank and fuel pump as long as your doing that much you may as well get the newer plastic tank it won't rust the way your old steel one will eventually and you will have the correct pump for the lt-1 even though i belive the tpi pump would work never hurts to be sure
Old Jan 24, 2003 | 04:03 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
The LT1 tanks arent plastic, dont bother with it, you didnt specify if your RS is a V6 or V8 car right now, what mods or parts do you have on it, etc, is the motor / trans from an f body, what year is it.
Old Jan 24, 2003 | 04:54 PM
ZipTriX's Avatar
My RS is a 305 V8 TBI right now.
Mods I have right now: Flowmasters, high performance 700R4 tranny and high flow thermostat and water pump.
LT1/T-56 coming from 1995 Camaro Z28. 67k miles on the motor.
Old Jan 24, 2003 | 05:25 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Get yourself LT1 Edit to remove the vats and stuff www.carputing.com
A set of 3rd gen headers.
a new set of poly motor mounts and a trans mount,
T56 crossmember from spohn, or their crossmember / tq arm.
fuel lines you can have made locally or get at www.lt1intake.com i think.
fuel pump, a stock replacement one for TPI will work, but i'd get a tpi upgrade one from www.racetronix.com.
a Manual trans shift plate for your console.
the radiator, hoses and heater lines from the 4th gen.
Old Jan 24, 2003 | 06:29 PM
ZipTriX's Avatar
Shift plate is the center console right?
Old Feb 9, 2003 | 02:05 AM
Dean-B4C6SPD's Avatar
Just mentioning cuz you didn't state it...
You didn't mention:
LT1 intake manifold
throttle body
clutch hydraulic lines for T-56
Then,
You'll need to figure out the A/C lines and power steering lines.
Then, either block the EGR off or get the EGR valve and hoses...
And...cap off the air pump or use the air pump...
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
sreZ28
Aug 14, 2015 07:48 PM
Thirim
Aug 9, 2015 06:19 PM
