help with block ID
Old Feb 4, 2003 | 02:11 PM
CEDOE's Avatar
help with block ID
14093638...350...87-95...2 or 4...Roller or flat tappet cam
one-piece rear seal
copied from mortec.com
IS THIS THE SAME BLOCK I HAVE NOW IN MY 89 FORMULA 350TPI
L98
The reason im asking is i can get all the prepwork done on this block then pull mine reuse the crank(polish) and rods and roller lifters ,then reassemble and put back in with less down time for machining.
This block does not have roller lifters in it now.could i use my lifters in it.(if they are good )
thanks
Old Feb 6, 2003 | 11:22 AM
CEDOE's Avatar
ttt
Old Feb 6, 2003 | 01:03 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If the retainer bolt bosses for the lifters and cam have been machined, then you can do what you propose.
Old Feb 6, 2003 | 02:18 PM
CEDOE's Avatar
Thanks, five7kid
However i wont be using that block cause i just picked up a nice 84 4X4 S-10 blazer for almost nothing(i love crackheads).so i will be driving that while my engine gets worked over and as a work vehicle . Then im gonna put the other block in the S-10 when i pick up a few bucks!!YEEHAAA!!!
Thanks again
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
