2 B 383 or not 2 B 383 That the ?
Old Feb 8, 2003 | 01:16 AM
pitzzilla's Avatar
Car: 79 ELKIE
Engine: TPI 305
I am getting ready to TPI my 79 Elky but desided to use a 383 for the tork :} will the 85 TPI system work on the 383 and what changes will be needed to I know I would have to change the knok sensor to 350 what other changes are need to make it happy or should I stay with the 305 or maby a 350 dont what to spent to much on it right now what about a 400SB? money in pocket need to diside before wife what money for her 80 elky or her hair
Old Feb 9, 2003 | 02:33 AM
Kandied91z's Avatar
i am really confused on your wording but with that aside of course you can run the stock tpi setup on a 383...as to why you would want to do that though is beyond me since it's so restrictive.
Old Feb 9, 2003 | 08:51 AM
pitzzilla's Avatar
Car: 79 ELKIE
Engine: TPI 305
what would be wrong to tpi a 383? I have a choice stick to the 305 or buy a 350, 383 or 400 since Im going to buy a new block i want the most i can get (cubes) that will work well with the stock tpi and will improve as I upgrade the tpi. will there be any change needed to be done to go with more cubes
Old Feb 9, 2003 | 09:34 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Nothing other then a stock setup will work with a stock setup. If you a different motor you need to mod the computer, and go with aftermarket TPI parts for it to work right. It a waste of time and money to use stock TPI on anything other then stock.
Old Feb 10, 2003 | 01:27 AM
D Stroy H8's Avatar
Car: 1990 Iroc-Z
Don't listen to these madmen!
I am about to make a SHOCKING statement!
Over the past month or two I have become a known advocate of the LTR intake. When people tell you that TPI won't breathe enough for a 383 they are in a sense absolutley right. That is, a stock TPI unit won't breathe enough. If you wish to keep the TPI I would strongly suggest upgrading it. Man, a worked aftermarket LTR setup is a badass intake. I would say that LTR's have to go when it comes to anything larger than a 383 tho. I'd say a superior LTR setup can breath a 383 but anything larger and you're pushing it. So this is what I would do; I am assuming you have some financial room to move. I would purchase an Edelbrock base manifold and runner set. Port out the the ends of the runners, and then portmatch both the plenum and base to the runner ends. Edelbrocks unit flows better by a longshot than stock, and the work you'll do will only make it better. You can then get the "e-bay" rebate by auctioning off your stock base and runners.
Old Feb 10, 2003 | 02:13 AM
Kandied91z's Avatar
alright, all things considered..........how much can your modified LTR setup run with that 383?
how many rpm's will it see? how much horsepower will you loose?
not to say it can't be done, but why? if your putting the obviously large amount to go 383+ why limit your power with a restriction like the tpi intake?
not that i'm against saving money and using what you have, but building a good longblock only to restrict it seems a little odd.
Old Feb 10, 2003 | 06:59 AM
pitzzilla's Avatar
Car: 79 ELKIE
Engine: TPI 305
its looks like I going with the 350 do do the 383 is to many ifs and but the 305 TPI any change to use it on the 350 as to sensors, i am going to covert my 350 block to roller cam any comb suggestion so far I have the headers TPI considering using vortec heads I guess that leave thecam only open for discussion
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
